BobsYourUncle
Apr 24, 2022Nomad
One consideration with this is the overall integrity of the unit.
While you are likely to be able to remove it easily enough, with the exception of any wiring that may run through, every partition, wall etc is part of the strength deigned into the unit. They are all there to reduce flexing while going down the road. This is important, and I wouldn't remove it.
As sdcampowner suggested above, the walls are on top of the flooring and the ceiling sits on the wall. This again lends strength to the unit.
As Scott said, do check first to see what is inside the wall. Be sure a grey or black tank vent pipe isn't in there too.
Removing a partition needs careful consideration. I personally wouldn't do it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
