rambleonrose's avatar
rambleonrose
Explorer II
Sep 22, 2018
At what point do you call it quits on repairs??
Hello all!
I'm a newb here, but seasoned forum junkie elsewhere. Also heavily seasoned in tackling projects that end up being way over my head. Raise your hand if this applies to you.
Long story short - I purchased an older RV early this summer. Knew about some small roof leaks, and in the process of fixing them, proceeded to make things worse. Decided to pull out the inside ceiling and add cross support beams and seal the roof outside. (side note - I'm fairly certain the roof hasn't been sealed in ages....)
With the bottom of the metal roof now exposed on the inside, there appears to be so many small pinholes in it it could be a starry night scene. From corrosion, from wear/tear/shoes/??, who knows, there are a LOT. Iffin I had extra money, I'd look at this as just replace the whole **** roof.
So my question to you, fellow repair folks, like any unintentionally massive repair project, where do you draw the line? When do you say, 'nope, this won't be worth it' or 'I don't think I can actually fix this'??
How much in over your head have you been willing to go, without knowing if there would be a positive outcome?
I'd note that while my RV remodeling is rather limited, I've done loads on old houses - carpentry, wiring, tiling/floor, and all that jazz, so I'm unfortunately familiar with all the unforeseen problems.
What say you? When is enough enough?
  • Honestly any old RV in need of repairs is probably already junk and,should be qvoided. You will never recover your investment. If you want to just fix it up for a year or two, koolseal the roof.
  • When the project starts to become real work or when you call it the "project from hell" ... time to find another project.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
