I have had zero luck with command hangers. WORTHLESS! Our humidity is too high and this time of year with temperatures dipping into the mid 40's and back into the high 70's to low 80's, the walls sweat and the command products only last a day or two and fall with the weight of a small broome I had hung. Tried one for a hat hook, no go, tried several for aluminum ladles and spatulas...2 days, FAIL! Having said that, I even tried double sided industrial sticky tape to hang some led puck lights.........FAIL! I am in Louisiana and these products might work in a controlled humidity environment, but the rv sweats and these sticky products are all no good for our needs.
