ependydad's avatar
ependydad
Battery Bank - wire for 12v, 24v, or 48v?
I have four 12v 100Ah Battle Born lithium drop-ins. I'm looking towards the future using Victron components:
- 3,000W inverter w/ hybrid load-support
- solar charging
Currently I have a built-in generator for charging batteries.
If I went with 24v or 48v, I'd need a DC-to-DC converter to step down to 12v to run the existing RV systems (slides, lights, thermostat, fans, etc.).
So, what would you go with? 12v, 24v, or 48v? And why?
  • 48 volt. The higher the voltage the better. It will give the most margin between "full" and "empty". It also greatly reduces cable complexity and voltage drop losses.
    A DC-DC converter is super easy, get one with a read-out on it so you can dial in a nice stable 13.5 volt output and leave it.
    Something like this unit:
    DROK
    Install it in your distribution panel, rip out the old 12v converter.
  • Is there any loss in stepping down? Becomes important when you go solar.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Sep 13, 2025
