donn0128
Sep 06, 2018Explorer II
What is your tow vehicle?
Typically without a factory setup the easiest way is to go buy a battery isolator and run a dedicated line from the isolator to the 7 pin plug at the back of your tow vehicle. Then run a wire from the trailers plug pin to the battery plus. Correct pin outs can be found all over the the internet. Just search for Baegman wire schematic.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
