KD4UPL
Sep 06, 2018Explorer II
The voltage regulator in your tow vehicle prevents overcharge, same as it does for the existing starting battery. You need to add a charge line and probably a heavier ground than what your 4 pin has. That's why they make 7 pin connectors. Get rid of the 4 pin or at least add the 7 pin beside it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
