DougE
Sep 07, 2018Explorer
If you run directly from the vehicle battery you are in danger of drawing it down such that it won't start the vehicle. A direct connection is fine if you only use it while traveling. Otherwise use a small generator and a battery charger.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
