Matt_Colie
Feb 15, 2021Explorer II
PanhandlePlainsman wrote:
I'll check on 20 amp chargers.
It's hard to believe all WFCO's are faulty. I'll try to do some testing.
thanks again
Pan,
A 20amp stand-alone will take a very long time to recover a pair of GC2s to full density. Most stand-alones do not have the high terminal to get the density up where you need it.
It is not that all WFCO's are faulty, they were just not made with attention to detail that we can count on from a PD or IOTA.
Wire size is often an issue in DC systems because the working voltage window is so small that even small line losses can be a big problem.
Matt
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
