pianotuna
Feb 15, 2021Nomad III
wopachop wrote:
Ive got 2 GC2 from costco. Will unplug the trailer and run the furnace and things off the battery. How many amp hours should i take out before plugging the trailer in to charge? I only want to drain the batteries enough to determine if my WFCO is charging at 14+v.
I would go with voltage not amp-hours. If voltage is 11.8 under load (furnace, lights, and etc), it is time to charge.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
