time2roll
Feb 16, 2021Nomad
I believe the trick is to get the converter voltage to sag to 13.0 or lower during initial charging. This is actually very difficult even with #2 wire connecting the battery. BTDT. The battery voltage actually pops up fairly quick at 60 to 70 amps plus the voltage drop in the wire and the WFCO is doomed.
If I fire up the inverter/MW pulling 160+ amps while the WFCO is charging it will shift right into boost mode.
Yes I believe the WFCO is supposed to give about 15 minutes of boost mode about every 24 hours and is probably what you were seeing. And that brings me to another story of getting stuck overnight at 14.4 volts boiling my batteries away. Did this more than once. I had to give up at that point.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 24, 2026
