allenm wrote:
Hadn't thought about a flasher like SoundGuy shows. Great idea! Did you just use a standard flasher?
Any automotive flasher will do but I did happen to use a so-called "heavy duty" flasher as that's what I happened to have on hand. Although activating the running lights does make it a lot easier to find our campsite on a dark, moonless night I use the flash feature
every time I back our trailer on to our driveway as doing so makes what I'm doing just that much more obvious to other drivers than simply turning on the 4-way flasher which flashes just the tail lights. It's also a big advantage should I ever have to leave the trailer unattended on the side of the highway for a period of time - the more obvious the trailer is, the better. :B
