Adam_H
Mar 26, 2015Explorer
Funny thing is, this fridge draws as much as the 10cu/ft ones I looked at. Also, the really small one I have at work has the same specs. Go figure.....
Specs on the inverter call for .5a no load draw but when I measure it is .18a???
Fridge cooled in less than 2 hours with nothing in it to help, still empty and it is at 0deg freezer and 28 fridge set on 4 out of 6. Ambient temp is about 75deg. Going to open the garage and let the sun hit it for a while and see.
Compressor temp is the same as when plugged into the house and no additional noise on the cheap MSW inverter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
