jeepdave's avatar
jeepdave
Bent axle upgrade
It seems my axle is bent. I have a single axle 20' trailer rated at 3500lbs. I want to upgrade so this does not happen again.
This seems to be a common occurrence
Can I replace the axle with a 5000lbs and keep my hubs and brakes. Hoping I can go this route so I don't have to change my sweet aluminum rims. Lol
Thanks for any help
  • ETrailer.com they sell upgraded axles and disk brake conversions. Even new axle with disk brakes already installed.
    Your light trailer would not need disk brakes, but perhaps someone else reading this - it can help.
    Good luck with your project!
    Fred.
  • Both tires bent in. Tops wider than bottom. Inside of tires wore out.
  • It seems my axle is bent. I have a single axle 20' trailer rated at 3500lbs. I want to upgrade so this does not happen again.
    How do you know it is bent? All axles on trailers come from the factory with a slight up bend in the middle to accommodate wheel camber. How do you know it is a common occurrence? Going to a bigger stronger axle usually changes the bolt pattern on the wheels.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,377 PostsLatest Activity: Jul 17, 2025
