RoyB wrote:
ryanw821 Do you know if these LEDs have any regulator chips on the inside.. I'd be interested in these if they did not have the regulator chips.
If you can look inside maybe you can tell if one is there... It will be a small chip with a few resistors etc around it on the circuit board...
If the spec mentions the LED will work with a DC VOLTAGE range from 7-36VDC would require one. Without one the specs might say it will work from 12-14VDC.
The BUCK BOOST regulator chips give out RFI SIGNALS that interferes with the HDTV signals especially when you are picking them up using your OTA BATWING antenna.
EDIT NOTE: This request also for PORIGGITY
Roy Ken
Mine DONT have regulator.
