Veebyes
Dec 31, 2015Explorer II
A boaters mind coming at you. From what you say the roof seems to be in good shape & already coated with epoxy. By that I assume epoxy resin as used in boats. Tough stuff.
I had a boat with a cockpit deck constructed much the same way. Topcoat used was epoxy paint. Not the 2 part type. Very durable especially if more than 1 coat is applied. A good idea to have the paint shop mix in non skid grit otherwise you will have one very slick roof.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
