Jim-Linda
Mar 14, 2015Explorer II
Another option without holes is... mount the antenna on a pole, clamp the pole to the edge of the extended slide, run the coax through the edge of the slide(a couple of inches from closing), when the slide is closed, the bulb seal will prevent intrusion of bugs, water etc. The seal also will not damage the coax. Takes about 5 minutes to install/remove.
Jim
Jim
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
