westend
Mar 14, 2015Explorer
Barney's marine through hole fitting is the best, allows a user to vacate the wire in the future and provides good sealing. If the OP just wishes to drill a hole in the siding, Geocel sealants are the best, IMO. I use Tripolymer 2300 which is almost the same recipe as Proflex RV but has better elongation and strength. The 2300 is available through my local roofing distributor for less than $10/tube.
Another way to accomplish the through-wall access is to use a plate and mount coax fittings on the plate. Seal the plate to the exterior of the RV. I did this for TV and radio antenna leads and used 1/8" polycarbonate. I did have to attach my antenna wiring inside the wall to the exterior coax fittings but I have permanent antenna runs that are now accessed by interior wall plates.
Picture of plate:
Picture of plate:
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
