Acei wrote:
...Dometic 320: This appear to be popular and it is gravity fed. It is also reasonably cheap. Obviously, uses less water per flush...not having to dump black tank as often interests me
How much water an RV toilet uses is dependent on how much you put in the bowl and how long you hold the handle/pedal.
Less water in a waste tank is a bad thing when the solids don't get carried out due to inadequate liquids.
Acei wrote:
So no one builds a high quality gravity based RV toilet that works well and will last?
I'm pretty sure 99.9% of RV toilets are gravity flush.
