nadkaw1957
Apr 28, 2016Explorer
DutchmenSport wrote:
Campers are built from the inside out. The booth was set in place before the walls went up. So the booth is screwed from the outside inward. (opposite than what you'd do in a house with the wall in place first.
Yep - I worked for a trailer manufacturer in a past life... it it's attached to the walls is more likely attached from the outside.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
