LarryJM
Apr 23, 2014Explorer II
jim behr wrote:
I have a 2012 3500 silverado and pull a 14000 lb 5th wheel. I want to switch out the standard tail lights to LED. I'm sure you all have done this, any advise?
Just be careful if you live in a state with vehicle inspections since the vast majority of LED replacement bulbs and even a lot of LED assemblies are not DOT approved and might result in a failed vehicle inspection depending on your particular state vehicle inspection requirements.
Larry
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
