Keith099
Apr 30, 2014Explorer
If you have Command Electronics taillights originally, Command sells a DOT-approved plug in replacement kit. Extremely well-built with its own custom PCB and lens. You use the same backplate, so no new holes or sealant on the camper. Looks clean, and it's DOT-approved.
Amperage on braking lights dropped from 10.5A to 1.1A. Running lights dropped from 4.2A to 0.35A. Since it's less return potential on the ground pin, in theory it should increase trailer braking power by a very small amount.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
