Gdetrailer
May 04, 2014Explorer III
burningman wrote:
Those look like a good deal, do you have any yet? I'd like to know the actual size of the modules.
The description says "Modules are linked on 2-conductor 18AWG zip cord, 161mm (6.5") center-to-center spacing. 3.75" wire between each module." I'd like to know what marker lenses I can fit those behind.
I'd like to convert all my truck, camper, and trailer markers to LED (I've only done the tail lights so far) and I don't mind modifying my own stock lenses. Actually l like doing it that way, my camper tail lights are custom LEDs behind the stock lenses.
Modules are 2 3/4" in length not including the wire
5/8" Wide
about 1/4" tall (or thick)
They are prepped with 3M double sided tape on the back and feature one screw hole if you want to screw it into place.
Model number is LX-ECO3S .72W draw at 12V
One of the reviews mentioned they work down to 8V, I didn't check that but for use in my marker lights I did have to add a resistor to dim them so they were not brighter than the other markers.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
