jim_behrExplorerApr 21, 2014Brake,tail and signal light conversion to LEDI have a 2012 3500 silverado and pull a 14000 lb 5th wheel. I want to switch out the standard tail lights to LED. I'm sure you all have done this, any advise?
32 RepliesReplies sorted by NewestShow MorerickeoniExplorerApr 21, 2014Check out the new high power LEDs. I have no hyper flash problems or bulb out errors with this style.mikeh449ExplorerApr 21, 2014super bright leds dot com will need resistor to slow down flashing
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
Related ContentCuring LED Turn Signal Conversion Problemsbpconversion goose neck conversionconversion kitReplacement brake light / tail lightMy AGM to Lithium conversion
