Vintage465
Jan 19, 2017Nomad
Cummins12V98 wrote:
Nice job! My critique, the table should be wider at least on one side to place a plate and seasoning. Also a few too many bolts holding the table, but it sure won't fall off.
Points well taken. The piece of aluminum was already that size. There is one size larger, but you saw how much room there is in the pic where the little grill is on top of the plate.....As far as the # of bolts..........well, that's my way of straightening out the 18ga. after it warped from my welding the 1-1/2" tube to it..........OK, and I like lots of bolts, and they're stainless, and counter sunk! Looks very "aircraft" from the top of the table!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
