- Dutch_12078Explorer III
GordonThree wrote:
What is the structure on top of the trailer called, the part that is holding up the walls?
Wall framing... - GordonThreeExplorerWhat is the structure on top of the trailer called, the part that is holding up the walls?
- Optimistic_ParaExplorerIf you're into this sort of thing, the Teardrops and Tiny Travel Trailers forum is full of threads devoted to building your own.
- Dutch_12078Explorer IIIThe aluminum siding is attached with VHB tape, so there's probably some give that will help mitigate the flexing. The frame construction isn't much different than the commercial steel/aluminum framed RV's.
- profdant139Explorer IIIThe steel frame will be ok -- but the flexing could do some interesting things to the exterior skin . . . .
- GordonThreeExplorerQuite a project. I haven't seen any hand made camping trailers that looked that nice on the outside. He really did well with the skin. The DIY trailers and truck campers around here are just plywood nailed together and painted.
I wonder how the ridged steel frame will hold up not being able to flex as the trailer trundles down the road?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 23, 2026
