swimmer_spe wrote:
I just got back from my local trailer shop.
$125 for the propane certification, and I can install it.
I need to contact the ESA for the electrical, but it should be about $500 for the certification.
You’re golden.
The only other issue, if you’re in a permanent spot it’ll be an easy fix, is that no matter what you try to do to keep the weight down you won’t match the featherweight factory build. You will need lots more support than originally used, 4 corner jacks will not cut it. You will also need to get the load off the suspension or you will never get rid of the spring.
Block the frame up perfectly flat & level BEFORE you start building or you will always have issues with doors & windows sticking.
Finally, plumbing is regulated too after the Walkerton fiasco so check ahead of time if you will be ‘plumbed in’ to the campground.
Just whistle if you have any other questions.
Best of luck.
