trailernovice
Dec 28, 2020Explorer
Tired of losing bumper end caps, I just taped a 'sticky back' piece of velcro onto opposite sides of the bumper, then ran a strip between them that could be pulled off and put back on...in my mind, the point was 'keep the sewer hose in', not 'impress the neighbors with my craftsmanship'
Another idea, since you're using a plastic tube, could be to simply drill a hole in the top and drop a 5-inch-long bolt with a washer into it...wouldn't bounce out...and, if that's the worry, tap a hole on both top and bottom and get a bolt and nut long enough to actually thread the screw onto the bottom end...again, may not be the prettiest but should work
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
