Gdetrailer
Jan 07, 2015Explorer III
davidshq wrote:
I stumbled across this article over at DIYRV: http://www.doityourselfrv.com/diy-camper-trailer-budget/
They took a pop-up trailer, stripped it down to its frame and then built a new one on top. It appears that this is not entirely unheard of - folks taking trailers and rebuilding them or starting from the ground up...
What I'm wondering is, what are the legalities of all this? If one were to build a TT, would one need to have certain legal reviews done to ensure it was road worthy, etc.?
Dave
Since you and I are in PA I can give you some tips..
If you have a good title which matches the frame VIN you can pretty much do what you want with it provided you keep the width under 102".
However you should be careful about the weights, in other words don't take a popup frame under 3K lbs then expand it, add dual 3.5K axles.. and run with 6K or 7K loads with a title of under 3K lbs which has different rules..
Under 3K lbs no inspection is needed and electric brakes are optional, over 3K you WILL be required a yearly state inspection AND must have electric brakes..
You also must follow all outside lighting requirements in order to pass state inspection (IE marker lights must be in proper places and in correct quantities for length)..
Rebuilding, you have two options for titling, leaves as the manufacturer or if you have highly modified the exterior which hides any way of identifying the OEM brand name you could apply for a special construction trailer..
The slippy slope of special construction is you must provide proof of purchase of ALL major components (axles, frame, ect)..
I would only go special construction if you want to erase the OEM name and date of manufacture from the title..
Building a trailer from scratch in PA is a real hassle for getting a title.. It can be done but you will have a lot of hoops to jump through.. Reusing a trailer frame with legit title gets around the hassle..
A quick rundown on PA titling goes like this..
You must have receipts for all major components (axles, springs, frame material and possibly the box)..
You must make sure you understand all requirements in size (width and length).
You must understand all exterior lighting requirements and place the markers in the proper placement.
For ALL trailers over 3K lbs GVWR you must follow the steps below..
Once trailer is built you then must find an inspection station which inspects trailers (not all do) AND one that is willing to pre inspect your work AND be willing to fillout all the proper forms (not all will be willing to do this).
You MUST take your home built creation to that inspection station (without any title, plates or inspection sticker) for them to perform the preinspection and the mechanic must fill out all the paperwork.. You MUST provide FOUR STRAIGHT ON PHOTOS OF ALL SIDES that must be sent in with the same paperwork the mechanic fills out..
You must pay the mechanic and pay the fees for the titling process upfront..
Then you wait.
And hope that your paperwork does not get rejected..
If you get a title only then can you get a plate (pay some more money)..
Once you have a plate then you will need to go back to the inspection station and have another inspection done in order to get the sticker (and pay the mechanic again)..
I chose rebuilding a used trailer, I was going to build from scratch by having a custom trailer builder build and title a frame for me then I would build the box to suit me.
I found a great deal on a badly water damaged trailer in the length I wanted and bought it..
HERE is my rebuild which was basically gutting inside and out.. Leaving only the floor, walls and roof framing.. Took nearly three years but it is they way we want it.
I chose to leave the title in the OEM name and year to keep things simple.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
