JrzflyExplorerDec 26, 2013Bunk trim helpI have repaired some water damage to my bunk. I took off the trim that holds the top and side exterior fillon seam together. I disposed of it do to condition. I bought new trim molding, shaped like an...Show More
AlbertaNewbieExplorerDec 26, 2013you need to cut small vees in the short L leg to bend unless you hit it with heat and stretch slightly
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 26, 2026
Related ContentBunk End Aluminum Trim RemovalBunks vs Bunk HouseReplacing trim/screw cover around door & bunk endsRamp TrimRemoving refrigerator trim
