I'm not being ignorant.
1) I'm going to get a portable back flow preventer to put on my non potable water hose when the spigot I'm using doesn't already have one. If the spigot I'm using already has a back flow preventer, then bad water can't back up anyway.
2) I don't hook up my black water tank flush until it's time to use it.
3) I dump my black tank before I used the black tank flush. I don't hook it up while the black tank is full. Nor do I use the black tank flush to fill the black tank.
5) As for water, I'm beginning to not even hook up the city water to my trailer. I will use the fresh water in the tank. When it nearly empties, I just put some more fresh water in the fresh water tank.
myredracer wrote:
We were in a large CG with a few hundred feet elevation difference from upper to lower sites. Someone at the bottom left their site and forgot to remove their city water hose. It ripped the faucet off and the CG had to shut their main supply valve off. So that set up the scenario for water being drained by gravity from all sites above the damaged faucet into the water distribution PLUS water from lower sites being siphoned back into the system. And if someone were flushing their tank and had no backflow prevention, could have contaminated the entire CG. We were leaving the CG that morning and didn't have to worry.
There are many, many real life scenarios where backflow and contamination can occur. It's not a theoretical other universe possibility. Go talk to your local public health authority and see what they say instead of being ignorant and possibly making others sick (or worse).
