Samanthahhi's avatar
Samanthahhi
Cabinet Door Fix
Seriously, I don't know what to call this and thus I am at a loss to describe it easily. But you'll understand my issue quickly enough.
I have 3 storage areas in my camper, above a window, in which the doors life up. Not, left, not right, but up. Yet, the manufacturer (and apparently after an exhaustive research of all new, even high-end manufacturers) didn't bother to sleuth through the need to keep the cabinet door up and open while in use. Therefore, you have to hold it with one hand while taking out whatever it is you need with the other.
Now, I have no doubt this hasn't pissed off many other rv owners and there must be any number of solutions. Yet, I have to come across one yet.
Ideally, I don't want to screw a hook into the ceiling to latch the door open. There must be some kind of hinge configuration that will hold it open.
And.....go! ;)
Samantha
  • Sounds like you need some gas springs on those doors. Hatchlift.com might have what you need.
  • small gas cabinet shock....like the ones that hold up the back window on a pick-up truck bed shell.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,382 PostsLatest Activity: Jul 26, 2025
