myredracer
May 09, 2016Explorer II
Those basic inline regulators have a low flow rate (about 1 gpm) and can easily plug up with sediment depending on the water quality. There is a very small hole that the water passes through and it doesn't take much to plug up the hole and regulator mechanism. There is a high pressure drop across these regulators which goes up as the CG pressure goes down. With low CG pressure, you can end up with a trickle inside. Not rebuildable. We had one in the beginning that only lasted 1 season.
You should always use a regulator and the inline ones are the least costly and simplest. An excellent upgrade is a Watts unit like the 263A and are good for over 4 gpm and are rebuildable. Can be used outside or inside. I installed one under our kitchen sink. The gauge in the photo is a tell-tale type and have seen as high as 135 psi at a CG so far. Some have reported as high as 200 psi. We use a high pressure rated hose to the CG supply. I installed a gauge after the regulator at the HWT have the reg. set to 60 psi. RVs are tested to min. 100 psi.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
