myredracer
May 14, 2016Explorer II
Bumpyroad wrote:
that gauge sort of looks like it has a red pointer which mine has that shows the maximum pressure reached. sort of interesting.
bumpy
They are usually called a "telltale" gauge and yes, are kinda interesting.
The red needle stays at the max. pressure that the gauge measures. It's resettable by twisting a little knob on the face of the gauge. The Watts one in the photo is available at Home Depot. Should be mounted with the threaded fitting facing down so sediment won't accumulate in it. I couldn't find one and mounted it upside down instead.
I used brass pipe and fittings between the regulator and city water inlet so that it won't fail if there is high pressure in a CG somewhere out there.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
