Chaz59's avatar
Chaz59
camco water regulator
Does the camco water regulator that walmart sells function ok?
thanks
  • Calbar, do you have pic of what you made or a parts list/cost? Thanks
    I have been using the Walmart version and it is ok, although one got plugged or something and failed.
  • You will probably find that it will regulate the pressure fine but you will not be happy with the flow of those cheap regulators. I put my own together with a house regulator, gauge and hose fittings. Regulates pressure to whatever I want and no flow issues. Got all of the parts at Home Depot.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Feb 21, 2026
