Gdetrailer
Apr 20, 2014Explorer III
Typically car stereos can be mounted at angles but you need to check your manufacturers installation documents. In there they WILL specify the max angles which a stereo can be mounted (different manufacturers and models will have different specifications so I can not say for sure what the max of your unit is).
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,406 PostsLatest Activity: Apr 28, 2026
