- goducks10ExplorerLooks like you get a lot of hanger flex after installing an LCI Correct Track.
https://www.youtube.com/watch?v=Bp5iRVPwYZg - BurbManExplorer IIII installed that kit to get a 2" lift when I switched to 16" LT tires on the trailer. After extensive measurements, I found after the kit was on that the chassis alignment was within specs, so no further adjustments needed.
- Swampman597ExplorerGreat, thanks for the replies.
The axle alignment kit looks interesting since I had to get my axles aligned in Eugene, OR. - ScottGNomadYes. But raising the equalizer 1" will only raise the whole trailer about 3/8"s.
- Old-BiscuitExplorer IIIIf you don't have means of raising (repositioning) the eye ends of springs you won't gain much height changing equalizer.
But you can accomplish two things with an 'axle alignment kit'
Align the axles AND raise height 2"
Alignment Kit - tvman44ExplorerNot very much if any. :(
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,396 PostsLatest Activity: Nov 18, 2025
