SCVJeff
Apr 30, 2016Explorer
They also sell insulation "nails". It's a small metal plate set in a fast cure epoxy or adheisive with a steel rod that you push the insulation down on, then push a keeper on the rod and trim off excess rod. Not a bad backup to adheisive on the insulation itself that does let go on occasion
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
