myredracer
Mar 02, 2014Explorer II
Take a look at this double recliner seating. De Leon double recliner. It is several inches shorter front to back when in upright position compared to other similar seating. It's the only one I've seen that will fit in the same depth as an RV sofa. And because it's RV seating, you can get it through the door.
We were looking at theater seating for our KZ but went with a factory hide-a-bed instead as the bed seemed more comfortable plus it can sleep more bodies than the standard sofa if we get company.
HeyJude wrote:goukcats wrote:
We replaced our recliners with theater seating. When purchasing the seating I insured the size was correct & the center console could be separated from the right & left recliner. It easily fit through the RV door, 1 piece at a time with backs reclined. Thanks to bro-in-law's help, lifting & reassembly was easy. Good luck.
Can I ask which theater seating you bought? I'm having a hard time finding something that will fit.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 25, 2026
