donn0128
Mar 20, 2018Explorer II
So, your plan is to circulate water out of the potable tank thru thr water heater? I assume your plannjng on some sort of bypass so your not trying to use hot water all the time.
Can it be done? Sure, anything is possible. Will the WH keep running and not blow out going down the road? Maybe, maybe not. Likely it will blow out, or burn a lot of propane trying to get all that water hot.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
