Old-Biscuit
Mar 20, 2018Explorer III
Fridge flame blew out cause of airflow thru lower access/vent cover....lots of airflow
Water heater.....outside door/panel is fairly enclosed so flame should stay lit/relight as needed
Issue......
Water going to tank will be 130*F/140*F (depending on which brand) and then once all the water is heated it will be HOT water in your fresh water tank
You mentioned 'others have done these'-----what/how did they do it???
They do make DC Tank Heater Pads. Easier to run larger DC Charge line from truck to camper battery to maintain camper battery drain
Issue......
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
