riven1950
Mar 20, 2018Explorer
Hot water does not freeze faster than cold water. It will lose heat at a faster than coldwater. At some point hot water becomes cold water and then the freeze rate is the same, if that makes sense. Put a bucket of 100 degree water and a bucket of 40 degree water outside in freezing weather and see which freezes first.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
