coolmom42
Mar 20, 2018Explorer II
time2roll wrote:profdant139 wrote:The system was recently upgraded to use the furnace signal to trigger the pump to come on. The more the furnace runs the more the pump runs. No chance to hear the pump while the furnace is running.
Someone asked for a link to an earlier recirculation project:
Hot water recirculator to prevent freezing of lines
So OP will be using both the water heater and furnace while on the road? Sounds a little tricky, but it might work.
It would be a good idea to put a remote temp sensor both inside the RV and water tank area, so temp can be monitored. If the furnace, pump, or water heater fail, things could freeze up.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
