BarneyS
Mar 20, 2018Nomad
pianotuna wrote:
Hi,
If the belly is enclosed and heated by the furnace then just run it instead?
I use a twin window fan to cause warm cabin air to circulate through the duct work. It draws a whopping 27 watts.
Don,
The OP stated in his opening post "(And I can't use my furnace to heat the tanks, both because it uses a lot of power and because there is no way to hook up a duct to the existing furnace.)"
His belly cannot be heated by the furnace as far as I can see according to what he posted.
Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
