pianotuna
Mar 20, 2018Nomad III
The fresh water tank in many RV's is within the heated space.
The issue is the lines--which the makers run along the outside edge of the RV where there is little air circulation unless the furnace fan is running. It is quite possible to have the living quarters at 21 C (70 f) and still have freezing temperatures at the edges of the RV. DAMHIK
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
