time2roll
Mar 22, 2018Nomad
Shurflow, Aquajet and Flojet all make variable speed RV water pumps. I have no experience with these pumps but I speculate they will operate much quieter. Especially if run at a restricted low volume of water. Use a foam pad to mount and use flexible lines placed so they do not rattle against anything.
http://www.campingworld.com/maintain-your-rv/fresh-water/fresh-water-pumps-accessories
Search for some reviews on these items.
A low pressure circulating pump may also provide freeze protection of your pipes. IIRC you camp with minimal use of the furnace so pipe freeze protection is also important.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
