ulvik's avatar
ulvik
Can you attach Big Buddy heater to ourside grill line?
Fixing to take a long trip up the east coast to Maine. I bought a Mr. Heater Big Buddy heater at Walmart on sale for $60 and don't want to use the small bottles. I was wondering If I could attach a line to the outside BBQ that has a quick disconnect and then run a line inside the camper to hook it up to the big buddy heater? If so I believe it is a low pressure line because there is a regulator at the front of the camper attached to the propane tanks. Has anyone done this and if so where did you find the hose and the quick connect fittings to do this? Thanks ahead of time!
  • You need a high pressure line to your Big Buddy. This line can be added to your coach. Using a low pressure line may keep the Big Buddy running (or not) but you will not be able to get the full output available.
    Don't use it while sleeping or it may be a very long deep sleep!
