candjmc's avatar
candjmc
Cargo trailer battery?
We bought 2006 continental cargo 7x16 enclosed trailer. I am trying to figure out interior light, looks like red,blue,black, and i believe white coming out of the wiring harness going uo into the trailer,but when I pulled off wall switch there was a yellow one there. .?
  • RoyB's avatar
    RoyB
    Explorer II
    ETRAILER.com is a good all around source of INFO for anything trailers...
    Roy Ken
  • So red and white would be typically used for interior light
  • 4x4van's avatar
    4x4van
    Explorer III
    For any trailer, you'll of course have running lights, right turn/brake, left turn/brake, and ground. If your trailer has brakes (my 16x7 enclosed trailer does), then you'll also have a wire for that. The standard trailer wiring colors are:
    Brown=Running
    Green=Right turn/brake
    Yellow=Left turn/brake
    White=ground
    Blue=electric brakes
    Red=battery/aux (this would typically be used for interior lighting)
    Purple=back-up lights
    Use a continuity tester and see which terminal (on the trailer plug) corresponds with each wire in your "box". Standard trailer plug layout diagrams can be found at etrailer.com
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
