TNGW1500SE's avatar
TNGW1500SE
Cargo trailer gray water tank mounting
I just bought a 12' cargo trailer. I have a Transit van with a bed but no bathroom or shower. My plan is to use the front of the cargo trailer to install a shower and a sink and two motorcycles in the back. No toilet is needed because I have a porta-potty. I'm looking to install a 20 gal (or so) tank under the floor to catch the gray water. Any advice on what's a good tank and how to mount it? There's 24" between the frame support that run from side to side.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    I was able to mount two 20 gallon grey tanks, plumbed together under my 14' cargo trailer. Depth is a big limit, so that's why I needed side by side tanks. Measured dimensions I could work with then did searches for tanks.
    As mentioned getting a vent tube up through the roof was problematic. I had built a shower stall/porta potty enclosure and ran the vent tube up through an edge of that enclosure.
    never have come close to filling the full 40 gallons. 2 gallons for a shower at most, 2 gallons for dishes, can take a while to fill the grey tank.
  • I put 3 class a custom tanks on my trailer, they fit nice between the frame rails. Getting the vent up was the most problematic issue for me, I used 1.5" angle iron and welded up frames for them. 2x20gal for fresh and a 20 for grey, it's additional storage for my truck camper.
  • Might be easier to add just a drain line and get like 3 aqutainers. 20 gallons for a grey water tank is small. Especially if you have a shower. Its doable, but probably not practical.
  • Utility trailers are sometimes low on ground clearance. Be strategic on where you place it. The one you are looking at is 8.5 inches in height.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
