JD_and_Beastlet
Jul 11, 2015Explorer
Centre stabilizing jacks
BACKGROUND
While camping we use the trailer's corner stabilizing jacks and we chock the wheels securely. Nevertheless, when someone is moving around in the trailer it's easily felt by those who are stationary. That's what led us to this mod - a third set of stabilizing jacks near the centre of the trailer to reduce the bounce and wiggle when parked.
These are scissor jacks rated at 2268 kg (5000 lbs) each. We got the pair on sale at Princess Auto for just under $50.
ISSUES
On the curb side of the trailer there is a propane line attached to and hanging down from the inside of the frame - you can see it in the photo above. My first thought was to use a spacer.
On closer inspection, I found I could centre the flange by grinding off a bit of the jack brackets.
(As it turns out, x=3/8")
Excess removed.
The brackets are painted and reinstalled on the jack.
ISSUES
Excess removed.
