navegator
Dec 01, 2015Explorer
Ceramic tile does not like to be twisted, a trailer will twist going down the road, those big motor-homes go from park to park and have pretty strong frames, the tile needs to be glued and the minute the trailer flexes the tiles will crack, from your post I read that you do go on rough roads one trip and you will have a lot of cracked and chipped tiles, and they are hard to remove once glued down.
You are better off with floating laminate, that is what I did after removing the carpet on my RV.
navegator
navegator
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
